08 700 dragon injectors not opening
Laid the used injectors/harness over motor plugged in. With a little fuel in the rail and some pressure it is flowing fuel out of the lower injectors.
So you could make the old injectors fire and spray fuel with a 9v battery?
The new ones would spray by just pulling over engine?
The injectors in the motor will open with a 9 volt battery. And fuel pressure will drop. Will not run. The new (used) harness and injectors i hooked up laying on top of motor the lower injectors are working when rope is pulled.
Should the brown with white coming from stator have coutinuity with the blue-yellow and with the green-red wires from stator? Could someone test there's at the plug and let me know what they r getting for resistance?
And I should have mentioned this earlier but my problem started
When the recoil rope broke..sled was running b4 it broke..took recoil off for repair and install it...that's when my problems started
If it happen after breaking pull start rope check the air gaps on your pickups. To far away from flywheel it won't have a signal.
Chev,
I don't believe BN/WH should have continuity with either of the blues. They are different circuits from the stator:
- BN goes with the DGs - Exciter Coil - Powers the Ignition Coils /
ECU
- DBs are for the injector coil.
I am finding the same thing that according to the service manual, BN/WH should OMH out to 0(zero), currently, I'm getting OL (open).
I posted about "D8 sputtering" at idle on another board as well.
