D duramaxdan Free Member Mar 11, 2012 #1 08 700 163 with a bd pump gas and mini cooler 12 psi on straight vp110 at 6 to 9000 ft it runs good but i think thiers more what are u running ? fuel gears clutching etc
T theshadowrider Well-known member Mar 11, 2012 #2 duramaxdan said: 08 700 163 with a bd pump gas and mini cooler 12 psi on straight vp110 at 6 to 9000 ft it runs good but i think thiers more what are u running ? fuel gears clutching etc Click to expand... I run same setup on a 08 800 14psi at 9000' on 50/50 avgas to 91 mix. Tried straight avgas but at high elevation seem to hurt throttle response. With the "update" head, which is just fairly low compression, I have found 50/50 mix is adequate. Last edited: Mar 11, 2012
