Hello guys I have read a few theads actually on Dootalk.com that talk about puting an 07 airbox on a 04 or the HO engine, what experience does anyone on here have with this mod??
Do you Need to change anything on the outer airbox or can you run the 04 outer airbox with the 07 inner box and if any Jetting is required would it be leaner or richer?? I am also putting on a oval design Dynoport can, what jetting would you think would have to be done with this can along with the 07 box??
If the airbox was not to work or be worth it what jetting would I have to do with just the can??
My engine is supposed to be all stock other than a Wiseco piston top end
about 700 miles ago. and Has the sock filter on the outside of the outer air intake.
stock Jets should be 400 correct??
Any advice or tips would be appreciated.
Thank You, Wildcard
Thank You, Wildcard
