07 600 rmk when starting jumps from forward to reverse and shuts down
After starting sled when starts in forward and suddenly kicks into reverse and engine then dies ???? Any ideas what causes this kinda new to sledding
Thanks for any ideas
Could be some moisture in the switch, had this happen to mine after washing it to put it away for the summer a couple years ago.
Something in the switch. Disconnect it and see if the problem goes away and if so then you know its the switch.
sled_guy
Same thing happened on my buddy's girls shift. Would pop in and out of reverse which turned to be moisture in the switch.
The switch sends a ground signal to the ecu, it's possible to have a shorted wire between the switch connector and the ECU. I'd disconnect the ecu plug and measure to see if it is shorted.
Does it do this every time you start it? How about with a little throttle applied?
did you get this figured out? kind of obvious but when mine is very cold it wont go into reverse until temps come up
