Are your sleds stock? What mods are done? Should not be a problem as the updated reflash is a lot better. Some guys with various cans are experiencing issues. Post whatcha got and Ill try to work you through it.
Ditch, yes you need to be running the 09 numbers. You will notice that they are way leaner in the mid range. This will clean up your mid #s. Your top end sounds just right.
MRQUICK: Same for you...try the 2009 setup. The update sets up the 2007 and 2008 sleds to the 2009 specs.
First ride to the mountains (0-2000 feet) on the new reflash... Not impressed at all. Sled is stock other than M8 gears, BDX intake, and an SLP can. Bogging at around 4-4500 RPM. Very poor throttle response. Fuel is at 41 psi. (our fuel is 4% more rich than lower 48 fuel) I'll try my D&D can and adjusting the fuel pressure, but I've pretty much given up at this point. Cat needs to get their sh!t together or take their junk back.
ok so i understand...there was a reflash for the 07/m8 that came out first early and now there is a second reflash..???...and its this second reflash that is far more effective then the first..???...thanx
MRQuick, post your #s and Ill look and them and get some revisions up.
