Hey. On my 07’ m8. It has the fox zero pro shock on the rear. It uses a needle to add/check pressure for it.
My question is can i use air to add to psi adjustments or is this a only nitrogen type shock? And for the how to part. I have the needle and a adapter to go from needle to a standard shraeder valve. Can i just stick needle into shock valve then attach my little fox shock hand pump to check and or add subtract air?
Thanks for any help
Thanks for any help
