B
bcflyfisher
New member
I have a 06 - m7 153 and did a few clutch mods. Took it out this weekend and have an initial shift problem. Primary clutch - 70 gram adjust wt, cat m8orange primary spring , secondary - stock helix, rk - tec secondary with the stock white secondary spring.
The clutch does not engage until I reach approx. 5000 rpm and it hits hard. After the initial engagement, it up shifts and back shifts ok with a max rpm of 8100 at approx 8000 feet elevation. The belt is adjusted with little belt deflection at the point of sqealing.
Is my primary clutch weight too light ????
Any help appreciated.
