Anyone got a good boondocking/hillclimbing clutching set up for a 2006 M7 w/ ovs turbo at 10lbs of boost (aerocharger)?
Take this for what it's worth but this is what I'm going to try. I have a cutler gold primary spring with cutler adjustables set about 78 gram weights in the primary.I have the culter secondary conversion with red/white spring and running a straight 44 helix. I don't know how good a setup it is yet but from what i hear it should work pretty good.
Alex
do you know what the specs are on the orange/white spring or how it is different from the red/white. When I called and talked to Dale he said the red/white would be the ticket. I was thinking the same think, for the m7, he might want to run a 36/44. I liked the take off I had with the 44/40 i ran on my sled before i put the turbo on.
I was gonna try something in the neighborhood of a 120-340 primary spring (polaris Green/Black) w/some 77 gram weights or I do have a set of 70-80gram cutler weights I could use. I use the stock 10.4 secondary and was thinking of using a 38/42 helix w/orange secondary spring wound up with 1/2 preload.
all my helix's I have are for N/A applications 36, 44/40, 42/36 progressive, 46/40, few others I can't remember. Think a 38/42 progressive cut would be the ticket for an all around good helix? BDX I assume would cut one?
