06 Crossfire and 07 M8 Bulkhead
P
PowderBrad
Hey Guys,
I think the 2 are interchangeable are they not? My 07 M8 needs a front heat exchanger, and I may have come across an 06 Crossfire bulkhead that has a good heat exchanger.
Can they be swapped?
I thought the crossfire had the same bulkhead, am I wrong?
nah they are different , it wont fit your dd either.
m and xf are the same , thats not the issue , its the years
Only area of concern is the heat exchanger. If thats the same size maybe it would work? I dont need the bulkhead, just the exchanger out of it.
How about an 06 M7, it should be the same, not? I may have one of those lined up also.
Thanks,
i dont think you can take the exchanger out , its welded into it.
just order a new bulkhead from babbits or rvsports and get what you need
Bulk heads
I have several bad bulk heads with good heat exchangers off M8 and M1000
