05 Vs. 06
Time to pick your guy's brains a little. Is there many differences between the two years. Did they change anything in 06. Found a nice 06 for sale. I know my parts off my 05 would work on it. So id def have a good set of spares. But Not sure if Polaris changed anything with the crank issues and all in 06. Thanks in advance for any good intel! :usa2:
4 injectors on 06 2 injectors on 05.
Higher fuel pressure on 06
steering hoop different.
steering different
chaincase shorter on 06
oil bottle different
A-Arms on 05 different that 06 and newer.
depends on what you wanna swap between the 05 and 06. i have both and its nice to have the stuff to "switch" if needed.
its pretty obvious what you can change, other then above..motor wise you can use the entire bottom end and cyl head and valves (not cylinders, wiring, ecu)
