05 ski-doo 1000sdi and wiring harness
Wheel House Motorsports
~~~AVAILABLE MARCH 22~~~
I have a 05 1000 sdi, the motor has just over 2000 miles on it with a crank i replaced as preventative maintnance about 500 miles ago. since the crank i have run pod filters and a thermostat so things inside should be perfect... the motor is in the sled and runs great... i can get some vids of it running this next weekend. i only need to ride it 2 more times when i go home, then im getting rid of the motor and putting in a new monster. I am trying to get a commitment on these ASAP as i am buying another motor but dont want to sell mine until i know i can get the other one as well.
Motor without primary or any electrical, $1500 + 100 for empty primary
primary and secondary both loaded with DJ kit and updated arms in primary - $250
ECU- $400
Entire wiring harness including ECU-$750
Throttle boddies $100
Injectors(4) $75
Rave motor $50
Ceramic coated y-pipe with digitron egt bungs in it. $200 with the double window digitrons.
bikeman mod pipe w/ very light surface rust $75 obo
HPS can, excelent condition $150obo
oil injection resivior $15
fuel tank with high pressure pump still in it $100
Low pressure pump wired for stock harness $10
Everything listed for $2700... all you need is a chassis and your ready to go.
PM with any thoughs you have... i would like get a commitment on the main $$ soon and the small stuff can be sold off later, i dont really care.
