05 RT1000 Stumble
Summit Kid
New member
My 05 RT has recently developed a nasty stumble/hesitation when getting into the deep snow. On the trail the engine runs just fine and acceleration response is fine. As soon as I hit the deep stuff the engine just seems to start missing and stumbling and the only way to bring it out of the stumble is to hammer the throttle and drive out of it. Any ideas as this sled has worked fine since new. Any advice is appreciated.
sounds like maybe the e-raves are getting sticky. pull em out and clean em, lift the sled so the track is in the air, open the side panel and make sure the cables are moving full swing when you mash it WOT and the rpm gets to around 6800-7000
also, is it like it wont pull rpm, like hangs at around 7000 and just is limp? if it does this and it sounds really weak, like no snap in the sound, then its the raves not opening, mine was doing it now and then, cleaned it, no propblems now!
Sometimes the outer intake screen for the outer air box will plug with snow and cause a bogg, I always had to continuously wipe of my intake grid during pow play.
Yeah I cleaned the E-Rave before my last trip and still the same issue. Ill check the E-Rave cable and make sure they are working properly.
Do you have a fuel control box on it ?
