05 RMK 900 Cylinder
M
Mech Engr
Looks like a small scuff at the top of the exhaust port. Plating doesn't look like it's flaking off and looks pretty stable. Rest of the plating looks fine. I was thinking about polishing up that small area then doing a light hone and using it as is. What do you think?
Thanks, John
Good to talk with you... give me a call if you need any other help.
MH
Nikasil
MH
Nikasil
MH, Thanks for the call and the help!
You mentioned checking the crank runout...wouldn't I need to split the case and remove the crank for that? If that's the case (no pund intended) what's the risk with not doing it now? I have no reason to beleive there is anything wrong with the crank at this time. In fact the sled was running great, I just wanted to make sure it keeps running great by doing all these upgrades.
