Went riding last week, things were good until I started pulling longer climbs. Noticed when the pull(rpm went down to 7000ish) got hard the engine seemed to go flat....not a bog but just not much there. Started trying to tune it out(It's an 05 with speedwerx pipe, y-pipe, mbrp can, sno-pro intake, RKT head and secondary and a boondocker box. Using an AEM air/fuel.) Found that at WOT it was good but if I let off in a climb and feathered mid to 3/4 throttle it stayed kinda flat. It's quite possibly not back shifting, but I did try to tighten up the RKT secondary, didn't change much. I'll try a stiffer primary (has 70g wieghts) with a yellow white spring.(I ran out of daylight) Elevation was around 5000ft. Tried adjusting fuel both ways....not much effect. Still learning to tune with the boondocker.I maybe don't understand the lo-mid-hi settings on the box...will have to do some more research. Anyway, not much there in the mid to upper unil WOT...when I would go wide open it engine would take a few seconds and then climb back up and run great. The engine tone would be different while lacking power too. Any thoughts? Never noticed this last year...since then came the y-pipe, sno-pro air, and RKT secondary. I heard that the stock air is best but I have and after market hood, anyone else had problems with after market air?
