wonderin what the reliability is on the 900s crankwise i can overlook the weight as long as the engines reliable.
I have almost 2k on mine without a problem. I have also done some mods to mine though. I do have the extra stops, the vents, only run the good belt and I retourque the clutch reularly. The radiator delete and change the pipe and can will releive some of the weight issue and also lightens up the front end to eliminate the diving issues that some had. I love my 900 and would say it is the best sled I have owened so far. I would not have anything other than this chassis now. Also new skis make a world of difference. I run powder pros and they work great. Simple maintainence and these sleds are a blast to ride. Power is NOT an issue ever. Good luck and enjoy the new sled.
You just need to do a few things to help prevent a problem from occurring like nmmiles said and re-torque your primary a few times to 96 ft lbs and then ride it.
stay away! unless its dirt cheap like 2k. your asking for trouble
A little OT; Should I use the same torque on my 755 RMK?
