stickshift69
Hi all been a while. Just cleaning up the 900 RMK for the winter and need to address some issues from last winter. Has SLP Pipe and map.
-After warm up every second or third ride the sled will die, I replace the plugs and good to go again.
-When warm shutting down it takes a while for the sled to idle down and will "diesel" (keep running) after I hit the kill switch. This happens quite a bit.
sled runs great otherwise. 87 or 91 fuel makes no difference. Don't run oil in the tank.
Parts changed within 1500 miles:
-Stator
-TPS (set correctly)
-Reeds
-Motion Pro Cable
-Fuel Pump
Parts not done since new:
-Coolant sensor
-Exhaust sensor
-Coil
-Injectors.
Any directions will be great. Long live the 900... Ill be here a while!
-Stator
-Reeds
-Motion Pro Cable
-Fuel Pump
-Coolant sensor
-Exhaust sensor
-Coil
-Injectors.
