04 summit 800 Base Gasket?
So I pulled the motor apart to replace the crank and forgot to save the base gasket. Now I dont know what thickness that i need to get. The motor is ported but i dont think that heads were changed. I ride in elevations around 6000 feet and run pump gas. Any suggestions would be appreciated.
Thanks
Bill
Since you have good porting, raising the port timing won't do you any good so go with a 5 hole. That will give good compression and still be safe on pump gas.
Have FUN!
G MAN
