D
diggerdown
If you add long risers, build a support for the steering stem. I used an old handlebar clamp and spaced it with a small washer between the halfs. Made a plate that bolted though the bolts for the top stem bushing and brought it out to give extra support above the original bushing. This added a lot of strength to the noodle stem! If you open you hood and watch down by your carbs you will se that the steering stem will rub on the carb boots when you start pulling on the bars. You will know when you have a powder bog! Proper jetting helps along with a front dump can or a very good snow deflector. I don't know about the Holz drop brackets but the SJ limited the transfer some and made a more controlled ski lift. The air intake by the chaincase should be blocked off, with extra air intake somewhere else. They suck in all the hot air off the can and pipe and also any steam under the hood. Makes for poor performance. Keep the track as loose as you can without ratcheting. Kind of sketchy but a few things to look at.
