A few days ago I asked for thoughts on my sled dying against a closed throttle. M8 ended up with the solution. The problem was with the throttle safety switch. Actually more with the cables. Between the throttle cable being a bit loose, the left hand throttle cable a little gummy and the attachment plate for the lefty the lever wasn't able to close completely. Finally got to ride yesturday and after a little adjustment and a little lube the problem seems to be solved. Never died once even after some long hard pulls.
Once again thanks for the responses.
