I installed new engine in sled today and no spark. Unhooked kill switch and key switch, replaced stator, coil and cdi with known good ones. still no spark. Any ideas? Anyone with a wiring diagram. Has perc reverse.
look at the wires you plugged into your coil and the wires you plugged into your temp sensor they are probably switched. the longer one goes to the temp sensor I think, but you can match up the wire colors also
