R
And no, its not the flimsy little key in the end of the drive shaft. Cable isn't broken either. How common is a failure either in the speedo itself or in the drive unit under the secondary?
Can you read?I'd check the driveshaft bearing first, pretty common failure if you don't grease them every few rides.
No hard feelings on this end, I was just trying to joke with you a little bit. Sorry it came off wrong.I can read and I see no mention of you checking the driveshaft bearing, I was just trying to help.
I have had the speedo quit working on two previous 02 RMKs and both times the driveshaft bearings had failed.
I will not bother you in the future.
Not pinched or melted by the pipe. The cable has a small crimp on each end that prevents it from being pulled all the way through from one end to the other.I'm betting that it is the cable broke somewhere in the middle. Take it off from the speedo end lift your sled and run it and see if it is turning???? Most likely pinched or melted from a pipe. Like was said, it should pull out of the casing.
