recently rebuilt chaincase, new gears and chain, started to rachit after about 500kms, also this is the 2nd time around, chaincase adjustment looks okay,track tension seems okay, its got me fuced?
what is causing the chain to keep loosing tension?
cheers in advance
I agree with ski, Check the drive shaft bearing on the clutch side also. I have seen them go bad causing the drivers to ratchet. The quy just kept tightening the track. When I checked the bearing, the bearing was gone and the drive shaft had cut a 1" path 2" long in the bulkhead and tunnle.
