So, my learning curve continues.
I bought a new track for my 03 700 and had never done much work deeper than the usual cleaning stuff--VES valves, blowing out the clutches, chaincase oil.
I was a bit intimidated at the idea of tearing it down to change the track, especially without a manual. As it turned out (as most of you already know) it's a fairly straight forward process.
When I got to the speedo cable housing I was a bit shocked to find the bearing destroyed...which explained why my speedo quit working. (I figured the cable nut had come loose and blew it off) The odd thing is I never noticed any grinding or strange noise. I don't feel like I've been negligent--I usually support my local wrencher when I find stuff I feel is beyond my ability, or if I'm in a hurry and need it done right, and quickly.
Here's what I have:
The bearing and bearing race were in chunks but the port in the tunnel for the bearing is undamaged.
No damage on the chaincase side but the speedo end of the jackshaft is scored a bit.
The speedo housing appears undamaged but I do need new square keys.
My questions:
1) Can I get a generic bearing from a bearing distributer?
1a) If yes, anyone have a good part no. ?
2) Do I need a new jackshaft?
2a) If yes, do I need special tools to remove/install the drivers?
3) If I go OEM is the speedo housing & bearing one assembly?
4) Is there anything else I'm overlooking before putting Humpty Dumpty together again?
Thanks
Here's what I have:
My questions:
Thanks
