02 SUMMIT 800 Intermitent spark problem
I have a 02 summit 800 which has a intermitent spark problem. I check the stator and the coil specs, which were ok. My question is, is there a wire or wires that I can unplug to eliminate the saftey/ kill switches?
Is the intermittent spark problem on one or both cylinders? Those sleds send a spark to both cylinders when each cylinder is at TDC (top dead center), the cylinder which is then at BDC (bottom dead center) still receives a spark but as the compression chamber has no viable air/fuel mix, and no compression in it there is no explosion, only in the cylinder at TDC but the spark still happens...soooo... if only one cylinder is not sparking correctly it may be plug wires or boots, super easy fix.
Yes it is dead on both cylinders, I've been a polaris mechanic for 15 yrs I know about 2 stroke theory and the spark on bdc and tdc. Was wondering if there is a wire to elliminate saftey stuff like there is on the Polaris's.Thanks
