01 polaris rmk 800
Spiderman
220
41
Mn
Check the fuel pump and fuel filter. Check the flow before and after the fuel filter.
Fosgate
10,995
5,306
Rapid City, SD
You can buy Service manuals from Polaris online for about $90 or google and buy a PDF file of it from a number of online vendors for $20-30. Might want to check your belt deflection, clutch faces or belt shine may be showing something binding. Pull the belt with the track off the ground and turn the secondary to see if the drive system is binding. Could be as simple as track tension with it off the ground and the chain case and the brake binding I have seen issues with 2 other sleds. II recall one was something with the brake rotors or pads. I don't recall what the other was. But they both dropped the rear suspension, pulled the chain case chain and found other minor issues in the process and used the opportunity to do some preventive maintenance.
