C
Well I made caps from a ‘23 165” work on my 24 pro 165” little bit of modifications needed, had to hog out the inner hole of the caps to allow the cross shaft to sit inside of the caps, and also had to trim the plastic spacer sleeves on the cross shaft. Didn’t have to trim much off the hyfax either, basically just squared them off.
I tried to use shaft sleeves from a 23 but the shaft diameter is quite a bit bigger on the 24.
All in it was $50 in Polaris parts and a couple hours of tinkering in the garage.
5458955- Rail caps x2 $15ea
5144351- Outer rail cap bushing x2 $8ea
This is on a 2024 850 Pro RMK Slash 165, using part numbers from a 2023 Pro RMK slash 165, your experience may vary….
![IMG_2026.jpeg IMG_2026.jpeg](https://www.snowest.com/forum/data/attachments/359/359006-99a5cd807e8703ecd0ebfbcc5b3278d6.jpg)
![IMG_2027.jpeg IMG_2027.jpeg](https://www.snowest.com/forum/data/attachments/359/359007-d1177ad497318bfaf2932a31bcae1034.jpg)
![IMG_2029.jpeg IMG_2029.jpeg](https://www.snowest.com/forum/data/attachments/359/359008-fb77f172cc2a6763057f0b5a3d67bd41.jpg)
