In case you haven't heard there seems to be a push on leak down testing.
850, 24 hours run time, 5.5% both cylinders. Using extreme oil. OTC gauge.
Explain leak down test.
I get all of that.A leak down test is used to diagnose problems with your engine. There is more things that can happen in 4 strokes that I would normally test for like leaking valves. This is just a basic description of how it works. I would go by the recommendation instructions on your tester.
"Basically" the testers look like an engine compression tester that also uses compressed air to build the cylinder pressure compared to pulling the engine over to build compression.
The piston must be at top dead center and fill the cylinder with the compressed air using the spark plug adaptor that should be included. Note that some older testers only had standard plug threads and many sleds and many newer cars have metric threads. Mine has the metric and standard adaptors.
The test results are compared to the other cylinders.
The leak down can test things like a leaking head gasket that you might find bubbles in the cooling tank while testing.
Each motor will have its own specifications from the manufactures.
I get all of that.
How do u get %?
Is it timed?
5% of 130psi over 10min?
Don't you guys get it? The only way we can get reliable and consistent results is if we all buy the same leak down tester from Indy Dan!
My .02, the LARGE majority of guys and gals that ride sled either aren't mechanically inclined enough to care or just dont want to spend the money on a leak down tester for a brand new sled that has 4 years of warranty. Especially when the majority of them aren't having problems. I agree there are some major issues for a few folks, but most are out there loving this new sled.
And the leak down test will only show the condition of the top end, it has nothing to do with a bearing problem which is the biggest issue we are seeing this far. I would be curious to know the mileage on these sleds that have lost crank bearings as well. Are they all or most in break in mode yet? Aka, fail right away or not at all?
There is a massive difference between ( not mechanically inclined) and lazy.
A leak down test should be done if you are having any kind of performance problem....... Bogging, hasitating, not going into reverse, hard starting.not pulling rpm, poor idling & so on.
Bearing problems ?????????? If you have a bearing problem...... The results are almost always the same..... The motor will soon lock up.
If you do a leak down on 2 different sleds.....
Sled 1 - has 6%
Sled 2 - has 2%
Then you go ride both sleds...... You instantly understand the value of a leak down test.
The 2% will run substantially better in every way.
The 6% sled needs top-end work...... No need to trouble shoot it until the top-end is fixed.
This thread proves.....that the masses would rather wonder what's wrong and talk endlessly about small problems then do a leak down test.
We did put in a large order of leak down testers that should be in soon and we are also going to do a YouTube video showing how it's done if anyone is wants to
See the procedure performed.
Dan
Fyi, Since December, when I picked my sled up, I have done 3 leakdown tests. Only because I was putting a turbo on and wanted to keep tabs on it.
I'll have to look at my papers for the last test after the turbo was installed
edit- by "cold" I mean heated shop at 60*
Thanks, that better than my description. I would rather copy the instructions off my tester, but its just like my neighbor to not be able to find the tools he borrowed when I need them back. Think my lending to him has come to a close. You should see how he returned one of my chainsaws lol.
Love thy neighbor must have some limits![]()
