850 Tether Connector for polaris harness, info on new connector
Looks promising!
If they used Deutsch on the whole machine it would be awesome.........
No kidding, going from some unsealed cheap connectors to Deutsch.. Thats a huge jump.
IMO these are some of the best connectors you will find. Kudos to polaris for not using garbage unsealed connectors at least in this application! This will add some serious value to the sleds and hopefully keep sleds holding value longer as they aren't shorted out electrical gremlins after 1k miles.
Any reason the Cat tether wont work with one of these connectors?
I don´t know if that i the case still but Cats tether switches used to be normally closed and breaks the circuit when the tether is pulled. Polaris switches are the other way around, normally open and closes the circuit when pulled.
Great info, but this won’t prevent Cat guys from switching to these sealed connectors.
AC has used a normally open ignition since 1998.
It is different. I just got mine today.
attachment.php
