I installed the SSI Mountain Performance kit on a 18 Mtn Cat. The kit I installed consisted of a SSI Billet head with inserts, Boyesen Rage Cage Reeds, SSI stainless steel Y-pipe, SSI titanium can, stock pipe which has the SSI pipe mod done to it and a SSI clutch kit specifically for this setup.
Install: The install was pretty simple as long as you are mechanically inclined and have basic hand tools for working on a sled. I replaced the stock reeds without having to remove the air box which was a big plus and I used a suck tank to evacuate the coolant from the sled to replace the head. I was surprised that almost every drop of coolant that I took out of the sled fit back in before I took it out of the shop and ran it with the front end raised up. I just pushed down on the rear bumper as far as I could and you could hear the air bubbles evacuating the system. Once everything was back together I did run it for a while with the front end elevated and managed to get a little more coolant in.
Now for the important part of how it runs. I was very skeptical of running this many add-ons without a fuel controller and I took it very easy for quite a while and checked the plugs often and even checked the wash a few times to make sure everything was normal. After that it was time to open it up for long pulls and see what it could do.
If you thought the throttle response was impressive on the stock DSI motor it is even better with this kit and the midrange pull is phenomenal!! I have had quite a few big bore motors on previous years sleds and this honestly feels like you are on a big bore sled. I did have an opportunity to ride this sled with a stock 18 for a little bit and it outdid the stock sled with ease everywhere we had the two sleds. There really was not much of a comparison between the two.
This sled at the time was not run below 8000' and up to about 9750' with the majority of the riding being done at 9250'. I set the magnets in the weights to SSI specifications and it was hitting the target rpm or just a little under the peak rpm of the kit. I tried to take a magnet or two out of the arms and gained some more throttle response on the bottom end but the peak rpm didn't go up much at all.
I did add a gallon of race fuel to a tank of premium just for insurance but don't think it will be needed at the elevations I rode at.
If you are on the fence about getting one of these kits don't hesitate. They run super good and the install is fairly easy if you have ever worked on your own motors.
"NOTE" I ordered the BDX ProMax Induction hood when I ordered the rest of the parts but they were waiting on the frog skins to show up and a new combination windshield gauge mount for the hood to be completed so I told them to hold off on that. I did have two 2" bulls eyes mounted on the factory hood behind the hood wings when I did this testing. Last night when I got home there was a box on my front step with the new hood from BDX. That will go on next and I will give a report on it in a few days. This new hood is very lightweight and doesn't feel like anything when you are holding it. It is supposed to be 8 to 9 pounds lighter than the stock hood with the headlight but I think it will be lighter the way it is designed and how lite it feels.
