I recently picked up a MY '14 PRO Ride RMK 155" as the previous owner's insurance company totaled it out due to what looks to be the stock can getting so hot it melted a lot of stuff on the right hand side. Side Panel and fender, coolant hose, noticed the starter bendix is quite worn so I'm assuming it at some point was trying to run and shaved 1/8"-3/16" off of the bendix gear. The CF over structure has a crack most of the way around about an inch above the lower right lug where they always seem to break (even though the owner has never rolled the sled, nor hit anything; the original owner used the sled exclusively for getting up our local mountains in order to snowboard / ski back down). Recoil rope is melted off. Coolant hoses, and can mounting rubbers are scorched as well.
The 800 caught both rings on the exhaust port on the MAG cylinder so it will get sent to INDY DAN to work his magic with a long rod. Meanwhile I'll put in a 600 for her to learn with.
I'm building it for my 12 year old daughter.
***Update***; I ended up selling the chassis (as this winter, jobs at work have been a little on the lean side). I have enough parts to build an Aluminum version of that I'd hoped would eventually become a full Carbon chassis. I'll be doing very close to the full extent of the light weight mods I've hinted at over the years. I will be doing my drop and roll and 9 tooth drivers this time around, and will be documenting the weight loss compared to stock and what I did to the stock and / or aftermarket parts to further lighten them.
