Quick Drive sprocket bolt inspection bulletin
F
frog
Subject: 2013 600/800 PRO-RMK Sprocket Fastener Replacement
Purpose:
The Polaris Technical Service and Snowmobile Engineering teams have received field reports of loose upper sprocket
fasteners on a limited number of MY13 600 and 800 PRO-RMK snowmobiles. Polaris has determined a loose upper
sprocket fastener can cause the jackshaft to move within the backer plate’s bearing. Because of the material differences
between the jackshaft and bearing inner race, wear can result between the components resulting in jackshaft failure.
To prevent both the upper and lower sprocket fasteners from loosening, the fastener torque specification is increasing
from 30 ft-lbs (40 Nm) to 45 ft-lbs (61 Nm) on both fasteners. Because the fasteners have a pre-applied locking agent,
the existing fasteners must be replaced with new parts. To facilitate this change, please follow the repair and inspection
procedures outlined within this Service Bulletin.
Polaris has determined that affected units with less than 500 miles (800 km) need only the upper and lower sprocket
fasteners replaced. Units with more than 500 miles (800 km) must have the jackshaft inspected because it is possible for
wear to occur at the jackshaft bearing mating surface if the upper sprocket fastener has loosened.
February 28, 2013© 2013 Polaris Sales Inc. Page 2 of 9
Warranty Coverage Period:
Warranty coverage for Service Bulletin S-13-01/A/B/C begins on February 28, 2013 and will expire on June 30, 2014. All
affected vehicles are covered during the campaign period. After the expiration date, only wholegood stock (WS) and
vehicles within the warranty period (including the ESC period) will receive warranty coverage. Vehicles outside the factory
warranty or ESC period will not receive warranty coverage after the expiration date.
S-13-01 Parts Information: 0 - 500 Miles (0 - 800 km) / Non-Electric Start Models
Fastener Replacement:
SERVICE BULLETIN # S-13-01
CLAIM TYPE SB (Service Bulletin)
LABOR ALLOWANCE 12 Minutes
CLAIM PART NUMBERS N/A - Auto Process Bulletin
WARRANTY COVERAGE PERIOD February 28, 2013 – June 30, 2014
S-13-01A Parts Information: 0 - 500 Miles (0 - 800 km) / Electric Start Models Fastener
Replacement:
SERVICE BULLETIN # S-13-01A
LABOR ALLOWANCE 18 Minutes
S-13-01B Parts Information: >500 Miles (>800 km) / Non-Electric Start Models
Fastener Replacement and Inspection:
SERVICE BULLETIN # S-13-01B
S-13-01C Parts Information: >500 Miles (>800 km) / Electric Start Models
SERVICE BULLETIN # S-13-01C
LABOR ALLOWANCE 30 Minutes
WARRANTY COVERAGE PERIOD February 28, 2013 – June 30, 2014.
© 2013 Polaris Sales Inc. Page 4 of 9
Parts Return or Disposal Information:
All jackshaft assemblies replaced as directed by this Service Bulletin must be returned to Polaris for inspection.
Jackshaft assemblies found to be not damaged and within specifications, will be charged-back to your
dealership.
For all other parts referenced within this Service Bulletin, follow the standard parts return or disposal information
outlined below.
Dealers & Distributors: Under no circumstances shall the part removed in this repair be re-used, sold, or re-purposed
for another application. It is your dealership / distributorship’s responsibility to make sure every part replaced is taken out
of circulation and disposed of properly.
For North American Dealers: Once the warranty claim for each unit has processed, please review the “Check Returned
Parts List” on your dealer website to determine whether or not Polaris has asked for the part(s) to be returned. If the
part(s) were not identified as needing to be returned to Polaris, please dispose of the part(s) properly.
Bulletin Completion Decal:
A Bulletin Completion Decal, PN 7170107, must be completed for this repair. Attach the decal to the air box assembly. If
you require more decals, order them through normal Polaris parts ordering channels.
Customer Notification:
Dealers are required to notify owners of affected models, and make arrangements to perform this repair. To view a list of
your dealership’s affected units, utilize Service Bulletin lookup located at:
In addition, Polaris will be mailing a notification letter to all owners of affected models. A copy of the letter can be found
on page 5.
Sincerely,
Doug Koch
© 2013 Polaris Sales Inc. Page 5 of 9
February xx, 2013
VIN
FIRST NAME LAST NAME
ADDRESS
CITY, ST ZIP
Dear FIRST NAME.
Thank you for purchasing a 2013 Polaris PRO RMK snowmobile. Our number one priority at Polaris is customer
satisfaction, and we know this is driven by product quality. Recently we identified a quality concern that affects 2013 PRO
RMK snowmobiles, including your machine. Please take a moment to review this letter and make arrangements with your
Polaris dealer to have it resolved as soon as possible.
On February 28, 2013, Technical Service Bulletin S-13-01 was released because it is possible your vehicle’s upper drive
sprocket fastener may loosen. A loose upper sprocket fastener may cause damage to the jackshaft or other QuickDriveTM
components. To resolve this issue, Polaris has provided your selling dealer with a service procedure and new sprocket
fasteners at no cost to you. Your Polaris dealer will install new sprocket fasteners using a new torque specification, and
perform a jackshaft inspection if required.
While the Service Bulletin will take less than 30 minutes to perform, dealer service schedules vary so please contact your
selling dealer at your earliest convenience to schedule a service appointment.
While your Polaris dealer is in the best position to answer your questions, if you have any questions your dealer cannot
address, you may call our Customer Service Department at: 1-888-704-5290.
We take quality very seriously, and want you to be confident we have taken appropriate measures to prevent this from
reoccurring. Thank you for being part of the Polaris family and allowing us to provide you with the ultimate deep snow
riding experience.
Sincerely,
Polaris Snowmobile Division
© 2013 Polaris Sales Inc. Page 6 of 9
S-13-01 / S-13-01A: 0 – 500 Mile (0 – 800 km) Fastener Replacement Procedure:
CAUTION: If engine has been running, verify exhaust system is cool.
1. Access the upper and lower sprocket fasteners. Lock the parking brake lever.
2. If the snowmobile is equipped with electric start, remove the battery from the engine compartment. When removing
the battery cables, disconnect the BLACK (negative) cable first, and then the RED (positive) cable last.
3. Remove and sprocket fasteners. Note the orientation of the domed washers.
4. Install two new fasteners (PN 7519004) with the washer domes facing out. Torque new fasteners to 45 ft-lbs (61 Nm).
Note the revised torque values in your Service Manual.
5. Release parking brake lever. On electric start models, install the battery. Connect the RED (positive) cable first, and
then connect the BLACK (negative) cable last.
6. File a warranty claim for S-13-01 or S-13-01A. No further action is required.
Dome side out.
S-13-01B / S-13-01C: > 500 Mile (>800 km) Fastener Replacement and Inspection Procedure:
3. Remove and fasteners. Note the orientation of the domed washers.
4. Remove the upper/lower sprockets and belt.
Dome side out.
© 2013 Polaris Sales Inc. Page 8 of 9
5. Release the parking brake lever. Remove the brake caliper fasteners. Use wire or tie strap to secure the brake away
from backer plate.
6. Note the directional arrow on the brake disc. Remove brake disc from jackshaft.
7. Inspect the jackshaft for signs of shaft galling and radial play.
Continued on page 9.
© 2013 Polaris Sales Inc. Page 9 of 9
8. If there are no signs of shaft galling or radial play, jackshaft replacement is not required. Proceed to step 9. If there
are signs of galling or radial play proceed to Jackshaft Authorization and Order Release section below.
9. Re-assemble the components removed to inspect the jackshaft bearing. On electric start models, install the battery.
Connect the RED (positive) cable first, and then connect the BLACK (negative) cable last.
10. For assembly procedures, reference the 2010-2013 PRO-RIDE Service Manual (PN 9923839).
11. When installing the upper and lower belt sprockets, install two new fasteners (PN 7519004) with the washer domes
facing out. Torque new fasteners to 45 ft-lbs (61 Nm). Note the revised torque values in your Service Manual.
12. Release parking brake lever.
13. File a warranty claim for S-13-01B or S-13-01C. No further action is required.
Jackshaft Authorization and Order Release:
1. If the jackshaft requires replacement, authorization through Ask Polaris will be required.
2. Submit an “Authorization – Non-cosmetic” case through Ask Polaris with clear photo(s) showing jackshaft damage. In
the case, make a request for one jackshaft assembly along with flat rate labor. Flat rate labor time for jackshaft
replacement is 1.5 hours.
3. Order replacement jackshaft (1332999) through normal parts ordering channels. Polaris Service is controlling the
release of jackshaft part orders and will only release orders for VINs with confirmed Ask Polaris cases. Because of
this controlled release, the jackshaft part number will show backorder status.
4. Install the new jackshaft assembly. For assembly procedures, reference the 2010-2013 PRO-RIDE service manual
(9923839).
5. When installing the upper and lower belt sprockets, install two new fasteners (PN 7519004) with the washer domes
6. Release parking brake lever.
7. On electric start models, install the battery. Connect the RED (positive) cable first, and then connect the BLACK
NOTE: Retain the original jackshaft for warranty parts return recall. Polaris will inspect each returned jackshaft
and undamaged jackshafts will be charged-back to your dealership.
Thanks for posting.
My upper bolt loosened just enough to spin the washer. I noticed it at 700 miles. No play in the jackshaft as of yet though.
Boy they sure do walk the techs through the procedure don't they. Like children.
Lawyers eh.
Didn't receive a notice yet from Polaris but called the dealer, and they show it needs to be done. Ordering parts now.
With the season winding down soon it will be nice to have this taken care of just in case.
Had my Pro in to replace a QD belt and they just got the bulletin. I got new bolts and they checked the jack shaft. That's not much torque on the bolts! I was so nervous I carried a 11/16 socket with me for a few rides to make sure it didn't get too loose. I'm sure many already know this, but it's a must to have the QD belt tools for install. It's tough w/o them. They are simple and lightweight.
I took my sled in last week for this recall and just called them today to find out the progress on it. They're waiting on parts...I'm getting a new jackshaft and possibly something else, the service manager wasn't in so they didn't know for sure. Looks like my quick drive belt I blew last trip is going to be warrantied after all.
The TSB turned into an actaul recall this Fall.
I'll see if i can find my old bolts Eric.
