ZR 200 brake questions
catzr
291
110
Selah
How do you bleed the brakes on a 2019 ZR 200
it has a hayes system
I dont have a Cat dealer close
Does the Little Polaris or Ski-Doos have the same system
MNBlizzard
249
83
Duluth, MN
I haven't done it in mine yet but it should not much different than a typical brake bleeding process. Open the reservoir cover, fill it, pump the brake, fill the reservoir as needed, open the bleeder valve on the caliper and pull the brake to force out any air, shut off bleeder and repeat as needed.
catzr
291
110
Selah
Thats what I thought, it hasnt worked out that way
This is a very small capacity system, thanks
M
Feb 7, 2009
1,142
606
Wabush, Labrador
it may be the same as the full size brakes.
I've found that just flicking the lever works rather than squeezing it. tap the banjo bolt, move around the brake line and situate the brake in a way that the bubbles will want to flow to the top and out.
Thistledoo
reverse bleed it....get a syringe....fill will the proper fluid and get a small piece of hose...loosen bleeder and slowly push fluid up and thru system...will work like a charm
soon as you see air bubbles and level rise out resivor be ready to tighten bleeder screw
catzr
291
110
Selah
thank you, I have a A C hayes kit coming , I may get to try this before it gets here
Trashy
69,576
7,327
Sherwood Park, Ab, Canada
I see that Hayes has a really good tutorial on their website that covers all their specific fittings and processes. I didn’t see one for the AC200’s tho, was for a MTB, but close enough.
catzr
291
110
Selah
found that video, its good. I picked up 2 syringes and hose from tractor supply today
had a chance to try bleeding once that way.
I am not happy with the results yet, making progress
the hayes kit should be here tuesday
catzr
291
110
Selah
I feel that I got the brakes to bleed and function tonight with the tractor supply
syringes and weed wacker hose, 10$ tools
Hayes kit isnt here yet, LOL
Thanks for the help
KMorgan
32
38
18
i tried the reverse bleed. didnt work. any ideas?
catzr
291
110
Selah
try turning the brake lever /res on the handle bars so the port is up
I had the best luck using 2 syringes with hoses. Push pull effect.
I pulled the brake pads out and used a spacer in the calipers for resistance
( plastic handled pliers fit in there well)
