98 RMK 700. i purchased it knowing something was wrong with it. the guy i got it from didnt know much about the mods as everything was installed before he bought it. this is what i can see on it so far....
SLP BOOST BOTTLE
HOT SEAT HEAD
GUTTED AIR BOX
STOCK PIPE
AFTERMARKET CAN (took it off, but cannot see a brand name on it)
STOCK CARBS KEIHIN PWK’S
-JETTING- (im not sure how accurate this is, but its what was installed when i purchased it)
i am at 1500' ASL
175 MAINS
42 PILOTS
R1371G NEEDLES
i have cleaned the carbs and made sure the jetting is the same on both carbs. the compression on both sides is right at 125. watch the videos of my egt gauges. you can see it is 150-200 degrees cooler on the LH side compared to the RH side. this temp difference stays consistant throughout the RPM range. it even gets a little more than 200* difference at 3/4 throttle to WOT.
something else iv noticed..... it will not run solely on the LH cylinder (while the RH spark plug wire is unhooked). it will pop a couple times and try to stay running, but it wont. however, it will stay running solely on the RH side while the LH spark plug is unhooked (obviously it runs rough because its on firing on one side, but it does stay running)
so, whats going on with my LH cylinder? any ideas? i just bought this sled and dont know a whole lot about it.....or it's history. when i 1st brought it home it wouldnt idle without fouling plugs. iv played with the carbs and it seems to be mostly over that problem. also, if anyone knows anything about the hot seat head, any info is appreciated. i see they have 3 different heads on their web site, but i do not see any markings on this head to signify which one it is.
at an idle
1/4 throttle
SLP BOOST BOTTLE
HOT SEAT HEAD
GUTTED AIR BOX
STOCK PIPE
i am at 1500' ASL
175 MAINS
42 PILOTS
R1371G NEEDLES
at an idle
1/4 throttle
