Z
I have an 05 grizzly 660 that has had a major engine failure 100-200 miles after a full rebuild with crank rod piston, but they didn't put in a new timing chain and i asked if we should and they said it didn't need to be replaced. Here is more of the story.
Here what happened at first. It backfires while trying to start. Just started smelling fuel in the garage and rode it a little bit and sometimes the smell would go away then it would come back for a while. THen it was running and a went to unload it from the trailer and it started and halfway off the trailor it died and wouldn't start since. THats when i noticed the fuel running out of the bottom of the carb. Put a new needle and seat in isn't leaking anymore but won't start. So then went to adjust or check adjustment on the valves and found all this.
Now to day my cousin and i decided to try and get this thing running has been sitting since 2011. So we were going to start by checking valve lash and found a buster rocker arm on the center intake valve. So then we pulled the valve cover off and checked the timing on the cam and found that way off and could spinn the cam gear by hand and the crank didn't turn. The timing chain was extremely loose. So we tore the head off and found a indention in the piston from the center intake valve and the center intake valve bent. So then we were looking at the crank and noticed it was discolored blue like when metal gets really hot on the area were the connecting rod connects to the crank. So i might i have something else going on here. Any ideas would be great.
I can't make it to the dealer till wed. to talk to them about this they are the ones that did all the work on the rebuild. Now this engine was rebuilt from the crank to new piston about 100-200 miles ago then i started having some problems. Im going to take the machine and all the bad parts with to show them and see what they will say or do. Any tips on dealing with the dealer too would be great.
