Water Pump Inlet
R
Dec 22, 2007
389
40
Alberta
Just looking at where the coolant goes into the motor and the pump cover has a smaller hose outlet is this a outlet or suction to the pump or a drain looking to use it to cool the turbo.
R
Dec 22, 2007
389
40
Alberta
Some good info there i realize you must create pressure drops in order to get coolant to flow from discharge of a pump [higher pressure] to suction where the cool coolant is lower pressure. Can use another pump to simplify and add to the load of the stator. Can use the circuit for my water to air intercooler but not sure how much heat the turbo will add to the coolant.
