Voltage regulator????
C
chadkrump
May 26, 2008
182
40
Amenia ND
Okay guys,
My buddy has a 98 XC 600... Started it up this summer to move it etc, and when he went to throttle up the lights flashed and then nothing, headlight and taillights do not work, but the gauges still light up... Im guessing the voltage regulator???
Anyone have any other thoughts about this?? thanks
CK
rmkboxer
323
83
46
Bonney lake WA
It could be the voltage regulator. I have one if interested. pm me. it could also be a short in the wiring but if the tach works then it is usually not a grounded out wire.
retiredpop
1,350
295
83
Calgary
It could be a corroded or loose ground connection on the voltage regulator. Do you have a voltmeter? You should read 10 to 15 Volts AC on a lighting coil lead to ground depending on rpm but not over 15 volts.
L
Jul 18, 2001
112
2
18
WA
volt reg
Sand the ground areas and install a new volt reg, they don't cost very much for that year.
Was this sled stored outside? Check other connections then before you install new bulbs.
C
chadkrump
May 26, 2008
182
40
Amenia ND
It wasn't sitting outside, so it was never wet... I have my meter here somewhere, just need to find it. I will check the regulator and see what is outputting.
I guess I could check to see if the bulbs are good too, but would be really weird if they all worked and then all of the sudden they all go out. Thanks guys!
CK
