Ultimate Boondocker Build
Teth-Air
4,562
2,791
Calgary AB/Nelson BC
www.specified.ca
Have you used these before. How important is the tension. Per instructions they want you to do it after the belt warms up.
I have used them for 9 years with the TKI gear downs. No problems. The tension is important as too tight will heatupnthe belt, like a chain and too loose it can strip teeth. Check tension when the geqrs are warm and expanded. The tension does not change much over time once set correctly.
