TPS Sensor on m7 Efi.
B
166
I was Running my m7 in the lot this morning and when i gave it gas anything above 1/4 throttle it wants to die. I had to blip the gas " on and off rapidly" to get it to move and put it back on the trailer. Could the TPS be the cause of this? is there any way to check it? my sled is underwarntee but Ac they wont cover it?
speeddemon
1,314
94
48
50
buckley wa
that is what mine did and it burned down at idle . ur dealer can test it . i found that the manual was wrong on the readings though . ez to change and check !
mike:D
westech
147
8
18
Vanderhoof, B.C.
Sounds like the throttle safety switch to me. It's a small switch built into the throttle lever....see where the lever pin is slotted. Follow the wire from the bottom of the lever area and unplug it. Hopefully that's all it is.
