Summit rev Xrs turbo
J
jskattum606
923
400
Bozeman, MT
I like it! Why did you get rid of the pictures?
Big turbo but try it and see what happens, Ive always wanted to try one
Wheel House Motorsports
29,933
5,970
SW MT
I have always wanted to try a 3582. given your elevation, i think you should have some good luck with it.
Curious to hear your results!
B
Boyko
771
260
Alberta
Well Played Sir
Should smooth out the exhaust pulse going to your turbo
The E85 thing is a little scary because your blowing a fuel that has corrosive properties around your bottom end bearings.
Daltech
754
371
North Norway
Ok, I have to ask, I`ve seen other mount it in the center with great sucess.
Don`t you have to take stinger size into account when the turbo is mounted in the middle of the pipe?
Love to see the outcome of this. Sealevel,so big is good. AR 84?
I played with ethanol in a NA build once. I did thou mix it down to E50. You get more gasolin to hold on the oil.
RDS88
281
36
Did you cap the end of the pipe, or plumb the exhaust of the turbo into it?
Would you post a pic?
