SLP single pipe 850 Matryx
madmax
3,146
Salt lake city
you have to turn in your core? Do they modify your stock pipe? Any one gave pics of the Carl’s pipe?
armey37
380
114
Richland,WA
That’s my pictures and sled. I mailed them my core and the new carls pipe showed up. Pretty easy swap.
madmax
3,146
Salt lake city
Talked to the “performance tech” at carls today about the 9R pipe mod. He said zero performance gain on a factory Polaris 9R. Only gain is on carls ported 900 motor and a 4lb weight loss from taking the cover off and the Cerakote coating.
armey37
380
114
Richland,WA
Correct. Mines on a 850.
wonderxc600
106
MN
As long as it doesn't hurt the power. I would do it for sure. Just for the weight saving. I believe he said it was half the weight of stock.
Lobster Carl
134
160
Unless he has a Carl's built 900 there is no gain other than a 4 pound savings.
The big question is has the runabiltly of the pipe changed with the shields and insulation gone with the cerakote taking its place? Better, worse, indifferent?
I'm all about shaving weight anywhere I can. But not at the cost of possibly making things worse.
Definatly following this thread.
Sheetmetalfab
7,911
6,673
I’ve ridden many sleds with removed heat shields.
Nose dip in blower powder and it bogs due to loss of pipe heat.
Cerakote is going to help but probably a good idea to run frogskinz on the vents.
armey37
380
114
Richland,WA
have you ridden with the carls pipe on your 850NA ? i wonder if you will be able to tell any difference
I haven’t. Just installed and talked to carls. I’m guess a little more on top end but nothing crazy. Stinger has been cut and welded. Seems a little longer. I don’t believe carls will sell/make something that’s going to hurt performance
madmax
3,146
Salt lake city
So since the carls 9R pipe adds zero power to a stock 9R and I do want the weight saves on my light weight 9R build. I pulled the cover off my 9R pipe today and sent it to get cerokote coated (same as carls does). Much cheaper than carls and the shipping that it’ll take. $180 to get costed vs over $400 to get carls with shipping and tax. The cam shell weighs alittle over 3lbs, so that’s that is weight savings, which is what the guy at carls told me.
BigAir
214
Montana
Is cerakote (or any other coating for that matter) going to hold the heat in the pipe as well as the factory pipe shield? Will there be a loss of performance in certain conditions if it doesn't?
