nah the stock mounts were fine, the TMIII and CompFusion mounts were "prevenative maintenence"
really..
i would just have to assume that your stock crossmember bolts were of coarse stock, and over time just wore out, backed themselves loose, and then coaused the vibration to bounce the crossmember and break it and the bolts..
^^now that is great troubleshooting, LOL!!
well that just goes to show you like you said..the TM crank and Comfusion mounts are simply outstanding!!!!
i cant find flanged replacement bolts, think i could just go with a washer and tones i can find are grade 9
Also make sure the MAG side REAR motor mount bolt is LONG when you replace it...some stock ones i have seen BARELY cleared the mount itself, and only caught the first 2/3 threads in the motor and ended up stripping out the hole...FYI!!!
I would think grade 8 bolts are grade 8. I was told its all about tensil strength polaris doesnt make the bolts they get the same bolts you or i would from a parts store, they are all mass produced. These are not my words this is a quote from somebody. Ive been looking for a grade 10-12 bolt, the next place told me i should use a grade 5 bolt because the strenth is weeker so instead of breaking they will stretch... What a dumb a$$. This was from a company that specailized in bolts. So watch what your told , Im not a bolt master but for rice sakes. Anybody got a story on the gr8 is gr8. Or was i bsed again.those bolts become more of an issue the more times they are worked on. I recommend they be replaced with a good brand name bolt when the engine is removed the first time. These breakage issues show up quite often with OEM Polaris bolts....EG: Team adjustment bolts, IQ front engine mounts, 900 cross-member ends.....you get the pic..
Does anyone have the size spec of these bolts handy? I don't have access to the polaris dealer site anymore to egt this info.
