91 octane only.hope the dealer or customer eats the bill if the engine sticks and doesnt ripoff cat for warrenty money.
Thanks guys, I filled the sled up with 92 octane toady and will run it with premium from here on out. I guess it makes sense that the sled should run cooler with 92 octane because it's harder to burn and less prone to detonation. Good tip.
I won't be able to ride tomorrow after all, so i won't be able to give any updates with the higher octane fuel. If the sled runs 75 degrees cooler (92 octane vs. 89 octane) than it would be about perfect. That would leave me at 1270ish on the temperatures.
I also added a SLP 120/340 primary spring last night because I was running 7,900 RPM and SLP said the pipe runs best at 8,100 RPM. I was really looking forward to trying that spring tomorrow too.
Oh well, duty calls, again.
premium is not harder to burn or slower burn its just resists preignition better than lower octane. once the plug sparks the fire is burnin'....
Oh I know several said to run premium. The problem was, at least as many people said to run 87. Not knowing who knows what on the forum is why I split the difference.
Don't worry, I will be using 92 octane from now on.
squarehead, 1215 is a little low to be getting worried, your not making enough power until at least 1250, carb sled or not, that doesn't change. I see 1350 or higher on my carb sled all the time, I just don't keep it there for long. The melting point of elemental aluminum is like 1220, but pistons have to have prolonged heat temps higher than that to melt.
If the temp to melt is 1220 than how can 1350 be an accurate reading, Maybe I should go lower my needles one notch, I don't understand?
