risers
J
jakim
167
17
18
Which bar risers do you guys like best for your King Cat. 30 degree angled or just straight cut. I plan on installing a wildchild post after it bends but for now it is stock but needs to be raised up. Thanks for your help.
80arrow
465
40
Grand Rapids MN
ole's riser it'll help move you forward some. They have an angled bottom(think its 30*):)
Rixster
3,781
651
Springville, UT
Get the oles riser and a 6 hole plate from them. the six hole plate moves the bars forward about 1 inch.
It works great with a 2.5 inch riser and a 6 hole plate. give you a total of 3 inches.
K
kidrman
1,183
142
Spokane WA
Had never seen that plate before. Looks like another must have part:D
I
Oct 10, 2009
50
10
8
SLC, UT
I have the same question, is the 2.5" with 6 hole plate the best set up for the 1m without extending cables? any disadvantages of the 6 hole plate vs. just a 3" riser?
Meatman
694
why fix a problem twice, get a forward mount post +2 inches and a 6 inch riser...hey look i got a extended cable for sale :D I went with the RSI risers....the look good and are a bit lighter
