5
Do they make a power value delete kit for a 2004 king cat. Also what is this suppose to help.
You'll have to bump the engagement on your primary significantly to overcome the low end bog as removing the power valves will decrease the low end but you'll see the benefit on top.
Removing the valves from any sled will do 2 thing:
1. Decrease you low-end power and torque - the port is simply too big to perform on the bottom. With the EFI sleds, there is a map for each valve position. Eliminating the valve will give you a larger port with the same fuel as if it was smaller. Not a good situation.
2. On the top end it will do nothing! Regardless of the various dyno sheets and claims, when the port is open with the valves or the valves are gone, the port is still only open so far. In fact, unless there is some spacer to fill the space in the cylinder, the exhaust will swirl upo the cavity, causing turbulance, disrupting the proper exit of the exhaust gas, and cause a decrease in power.
Bottom line, if your sled has exhaust valves, they were put there for your benifit: good low end power and high end power.
DTR
