T
The engine goes only up to 7000 rpm. it is a pro 5 ves 800 2005 mod,slp twin pipes, stingers, slp high octane head and v-force 3. I'm running avgass 100LL mixed with ordinary gas. The belt is 307*44. The gearing is 23/43. The primary has 10-64 weights and a black green spring. The secondary has a66.46.46/62.46.46 helix and a red gray spring. My jetting is 450. The needle is at the last clip. the number on the needle says Rn5-57. im driving from 0 to 3700 feet. My feeling is that it is to fat in the midle. Could it be the reson to my problem? Change to a thicker needle? I have checked the ves and both opens like they should. Could the problem be the outside temperature. Last day I did a test. I lifted the snowmobiles rearend up and gave full trotle. The engine stopped a fraction of a second at 7000 rpm before it vent up to 8200 rpm, which it did every time. Does anyone have an idea what causes the problem?
