Phazer Starter won't engage? Wiring melted!
Q
quadtrac
New member
Feb 27, 2009
116
1
18
39
Last week I completely tore apart my 07 FX Phazer to put in a left hand side frame casting. I had the engine out as well as the entire wiring harness. After I had everything put together and the wiring all routed and plugged back in, the starter will run but doesn't engage and turn the engine over. Also when I first tried to start the sled I seen smoke come out of yellow plastic piece that almost looked like a fuse by the oil tank. I then untapped the harness and seen that one of those little black wires was kinda melted that goes into the main harness. What did I do wrong? I am really confused on this one!
hcrider
156
34
wyoming
check with your dealer. i believe that there is a recall or bulletin on this and yor dealer will take care of it. this is one of yammi's few faults
Q
quadtrac
New member
Feb 27, 2009
116
1
18
39
Pulled the starter off and found thats its spinning backwards, How can it be doing this? Thanks
A
ak
2,776
723
theres a recall take to the dealer. for that yellow fuse block thingy.
