P-22 to P-85, is it a bolt on swap?
LoudHandle
3,900
2,777
Valdez, AK
From a few minutes of internet research; it looks like Polaris has again changed the crankshaft clutch taper size? Multiple times since the days of the carb’d sleds (30mm). (32mm) for the 700 and 900? Then (33mm) in the PRO chassis. And twice while in the AXYS Chassis. And Now with the Matryx chassis, what are they now? (I’m sure TRS or someone can verify). So I’m assuming the older Polaris-85’s need to be machined to the current taper? Is there enough meat on the clutch shaft to safely do this? Or is there a new part number for a direct bolt on?
If my internet sizes or wrong I’ll edit them. Thanks
Wheel House Motorsports
29,933
5,969
SW MT
The 850 p85 goes right in. Just requires p85 bolt & washer asswmbly foe the bolt ans then add the 1/4"x 1 set screw and lock nut for the secondary to do deflection.
TRS
Life Member
4,128
6,287
Cody, WY
Both use the 3211216 belt.
The part numbers you will need below.
You can source the secondary deflection screw and bolt from Polaris, Venom or TRS.
LoudHandle
3,900
2,777
Valdez, AK
Does a P-85 from a 2021 XCR 600 fit the 9R crank taper?
Not according to the official Polaris fische. No 600’s ever used that clutch. Even in the old days the 600 used the cheaper /weaker spider. So even if it did “fit” I wouldn’t run it. FWIW
F
Dec 30, 2019
146
181
Ok thank you. I just seen a near new take off clutch come up locally for a good price where the guy switched out to electric start.
kanedog
Undefeated mountain clutching champ of the world.
3,112
3,871
Loudhandle get yo ass back into this forum. Your wisdom is required on so many levels
F
Dec 30, 2019
146
181
Clutch for a 650 is the same, but not 600. I have a 400 mile take off 850 clutch if you one. $475 shipped
Thank you. When that one popped up locally for a song, I thought if it would work that I would grab it. Given all the work I did on my P22, I’m going to stick with it for the time being at least.
