2
2001 Polaris 700 Rmk overheats. I raised the front end up and tried to bleed air off but I get no antifreeze. Ok so here's what I've done.
* checked thermostat it is closed and works good.
* Checked water pump belt good replaced
* Took housing off and verified impeller good
* Run water through all hoses no plugs.
Ok put all back together started opened bleed off screw and still no water/antifreeze. Now I need some help any ideas e awesome thank you
