is there any way to tell if it is the stator or the coil? I took it apart tonight and one plug wire that comes out of the coil seems loose, or like it has be bent alot right as it comes out of the coil. I am guessing it is a coil. but was curious if it could be a stator? it ran fine 2 weeks ago and started it up to put it on the trailer and it was only running on one piston. thanks for the help in advance.
Try cutting your wire off and screwing it back in. a lot of times the wire breaks. It would not be the stator. the coil has a jump wire inside it that sometimes goes bad but usually just the wire or plug end.
Thanks for the help, I ordered a coil tonight, clipped the ends and the wire ohms out with a meter but switched plug caps and still no spark one one wire. Hope the ups man gets here before the snow melts!!!
