>>>> New FCC Rules that impact Snowmobilers
27,405
http://survivaldispatch.com/new-fcc-...hs_ovvfSzwUUAk
New FCC Rules that impact Snomobilers
written by survivald <time class="entry-date published" datetime="2019-08-12T08:00:27-04:00">August 12, 2019</time>
NEW FCC Rules that impact Preppers and New Hams
In September 2017, after a comment period, the FCC made changes to Part 95 Personal Radio Services Rules which included a restructuring and reorganization of the rules. Some of the changes became effective immediately and the final change becomes effective September 30<sup>th</sup>, 2019. Additionally, the FCC issued an Enforcement Advisory in September 2018 to give notice that the final ‘impacts’ of the new rules would come into effect a year later. Part of the changes to the rules included a reorganization and re-numbering.
This article will not go through all the changes, but we will highlight those that will have a direct impact on those who currently have and use the ‘cheap Chinese’ radios such as Baofeng, BTECH and some TYT and other radios that are capable of operating in several different radio services.
PART 95 RULES
Part 95 rules cover the Family Radio Service (FRS), the General Mobile Radio Service (GMRS), the Multi-Use Radio Service (MURS), the Citizen Band Radio Service (CBRSbut usually just called CB), Radio Control Radio Services (used for model aircraft etc.) and several other radio services.
LICENSE
There are two types of ‘license’ to use radio frequencies; one is a license specific to the radio service and the other is ‘license-by-rule.’ A license is specific to the radio service, i.e., if you have an Amateur Radio (ham) license it does not give you permission to operate in any other non-ham frequencies. Within Part 95 the FRS, MURS and CB are ‘license-by-rule’so you do not need a license to operation on those frequencies. GMRS requires a license; this is a simple application, $65 fee and is valid for 10 years (was 5 years prior to the rule changes) for yourself and immediate family. Immediate family members are the licensee’s spouse, children, grandchildren, stepchildren, parents, grandparents, stepparents, brothers, sisters, aunts, uncles, nieces, nephews, and in-laws(as defined in 95.1705 (c). The defining of who is an ‘immediate family member’ was an addition in the 2017 rule changes.
PENALTIES
Subpart A of Part 95 contains General Rules and there are several that you should be aware of.
Subpart (a) states that if a Federal courtfinds that you willfully and knowingly violate any provision of the Communications Act you can be fined up to $10,000 or be imprisoned for up to one year. If there is a subsequent violation imprisonment may not exceed two years.
Subpart (b) states that if a Federal court finds that you have willfully and knowingly violated any FCC rule, you may be fine up to $500 for each violation or, in the case of continuing violations, $500 for each day the violation continued.
Subpart (c) states that if the FCC finds that you have willfully or repeatedly violated one or more sections of the Communications Act or FCC rules you may be liable for forfeiture.
So, in (a) and (b) you are taken to court and they must prove that you willfully (deliberately, intentionally) and knowingly (had knowledge of the rule– by publishing them and by you using the radio services you acknowledge you know the rules).
In (c) it is up to the FCC to make the determination which means it is not a trial by your peers that decide.
NON-CERTIFIED TRANSMITTERS
There are a number of different subparts throughout the Part 95 that address the certification of a transmitter. This is probably the most significant change in the rules and the one that directly impacts the use of the Baofeng and similar radios that can operate in multiple radio services. If you have a Baofeng then you probably know that it will, right now, transmit across a wide range of frequencies; 136-174MHz and 400-520MHz. Therefore, these radios will transmit on all the radio services listed above as well as the Amateur Radio 2-meter and 70cm bands, a number of public safety frequencies and even the marine frequencies.
Many of the new subparts seem to be redundant, or perhaps written in isolation of the other subsections, but they make the point that the FCC does not want non-certified radios used in Part 95 radio services.
  • 95.335 states that you cannot use, with a few exceptions, a radio on any Part 95 radio service that has not been certified for use in that specific service. It also prohibits anyone modifying a radio so that it will operate in more than one service and using a transmitter that is not FCC certified voids your authority to operate that radio.
  • 95.337 states that you are not allowed to modify or operate equipment that has been modified.
  • 95.361
Subpart (a) states that each transmitter must be certified in accordance with the applicable subpart of the rules.
Subpart (c) states that certification will not be issued for a radio that has controls, switch or other adjustment that would allow the user to violate the rules. In other words, change it to operate outside the radio service that it is certified for.
  • 95.391 This is probably the most significant subsection. It prohibits the manufacture, import, sell or offer for sale non-certified equipment for the Personal Radio Services. No effective date is specified in this subpart, but the September 30<sup>th</sup>date is specified in other subsections.
Subpart (c) of this section prohibits voice obscuring radios, effective September 30th. There are a number of radios on the market (TYT is one brand I’m personally aware of) that have a voice scrambling mode. This is not encryption per-se but an inversion of the audio. Previously the FCC had issued an opinion that they did not consider this method as encryption because it was ‘generally available,’ meaning anyone with the same radio would have it. However, in these new rules the FCC has reversed that decision.
FAMILY RADIO SERVICE (FRS) – subsection B
Subsection B covers the Family Radio Service and contains additional rules specific to FRS.
  • 95.561 FRS Transmitter Certification Subpart (b) states that certification will not be issued unless the radio complies with all applicable rules (this would include subpart A General Rules).
Subpart (c) states that a certification will not be issued if the radio is capable of operating in any other subparts if [the manufacturer] filed for certification after December 27<sup>th</sup>, 2017. Essentially any radio made after December 2017 must meet the requirements.
  • 95.587 FRS additional requirements:
This section lists some of the requirements that a radio must meet to be certificated for use on the FRS frequencies. This includes a non-removable antenna that does not exceed ½ wave dipole. It allows brief data transmissions (under 1 second) as well as automatic transmissions if responding to a GPS/location requests. This is to allow some Garmin GPS (Garmin Rino series) devices to send their locations to similar units.
Subpart (e) specifically prohibits the manufacture or import of a radio that is capable of operating “in this and any other licensed or licensed-by-rule service” after September 30<sup>th</sup>2019. This will specifically prohibit the manufacture or import of the Baofeng radios that are currently offered for sale. Such radios include the UV-5R and variant handhelds, the BTECH UV-5×3 hand held, and their mobiles including their 50x and 25x series because they currently will operate in the FRS/GMRS/MURS and ham frequencies.
  • 95.591Sales of FRS combined radios will be prohibited after September 30<sup>th</sup>2019. Again, aimed at the Baofeng and similar radios, however this subsection only mentions hand held radios. If looking only at this rule it would be possible to offer to sell and sell the mobile radios such as the BTECH 25x and 50x series, even though they could not be certified, as long as they were not made or imported after September 30<sup>th</sup>. However, I personally wouldn’t offer to sell one of these radios on any public site/social media after the effective date!
General Mobile Radio Service (GMRS) – Subsection E
This section specifies who may operate a radio in the GMRS. It also expanded the license period from 5 to 10 years (same as Amateur Radio). Subsection (c) now contains a list of who the FCC considers family members that are covered under the one ‘family’ license; previously this had not been defined.
This section addresses the requirements for a radio to be certified to operate in the GMRS. It includes the statements (subsection (d) and (e)) that after December 2017 a radio will no longer be issued a certificate if it is capable of operating in both the FRS and GMRS.
In subsection (c) it also states a radio “will not be certified” for GMRS if it is capable of operating in the Amateur Radio service.”
As with §95.591 in the FRS subsection, this subsection also contains the statement that sales of radios operating in both FRS and GMRS are prohibited after September 30<sup>th</sup>2019. It also includes the statement that: “no person shall be permitted to manufacture or import, sell or offer for sale any radio equipment” that can operate in more than one service. Note that this subsection states “any radio” whereas in §95.591 is only specified hand held radios.
MULTI-USE RADIO SERVICE (MURS) – Subpart J
As with the other subparts this addresses transmitter certification and the wording in subpart (c) states; “certification shall not be issued if capable of operating under this subpart and any other subparts.”
FINAL THOUGHTS
While the FCC did clean up the Part 95 rules and did expand the frequencies for FRS by combining them with GMRS (with power limitations), they were not consistent in some of their wording in the various subparts. However, it is quite clear that the operating, manufacture, import, sale or offer for sale any radio that: 1) is not certified and/or 2) can operate in more than one service, will be a violation of FCC rules after September 30<sup>th</sup>. What is notably absent from the new rules is the possession of a radio that can operate in multiple services, so you don’t need to throw out all the Baofeng’s and similar radios (however, if you are worried about possessing a radio that violates the rules I’ll pay shipping and you can send it to me and I’ll make sure it is not used in violation of the rules).
Between now and the end of September I think you are going to see a lot of flash sales and then very discounted prices as none of the manufacturers or sellers are going to want to have any stock on hand after September 30<sup>th</sup>.
As always remember; fortuna favet paratus(fortune favors the prepared).
PERSONAL RADIO SERVICES – Part 95 MINDMAP
REFERENCES
BaoFeng BF-F8HP (UV-5R 3rd Gen) 8-Watt Dual Band Two-Way Radio
BTECH UV-5X3 5 Watt Tri-Band Radio
BTECH Mini UV-25X4 25 Watt Tri-Band Base, Mobile Radio
Federal Communications Commission Part 95 Personal Radio Service Reform, Report and Order, April 27, 2017
Federal Register, Vol. 82, No.166, August 29<sup>th</sup>, 2017
Federal Communications Commission Public Notice DA 18-980, FCC Enforcement Advisory, September 24<sup>th</sup>, 2018
Garmin Rino 750
Garmin Rino 755T
__________________
Scott
Scott Stiegler
69,618
11,737
W Mont
I read all of it.
Can I get a summary on this one?
"So I bought a programmed Baofang from that guy in Pocatello with all the BC Link, FRS and GMRS channels... So what this article means to me is...."
Teth-Air
4,562
2,791
Calgary AB/Nelson BC
www.specified.ca
I hope that Canada doesn't follow. I know the BCA rep in Western Canada and this will cause radio shortages for them if it comes North. Possibly it will anyway because the USA will take all the stock.
Mort2112
249
155
Meridian, ID
I'm not sure I understood this part correctly. Since I'm a BCA user this seems to eliminate the need for licensing at lower power settings (<=2W) is that right?
I use the higher power frequencies on my BCA since more power is more better but I was confused by that especially since BCA's high power is still lower than most of the competitors.
EDIT: Found the answer.
From BCA's site: With the latest changes to FCC Title 47 Part 95, all existing BC Link radios are operating as FRS radios (transmit power 2W or less and bandwidth of 25kHz) and therefore are license-free.
source: https://www.backcountryaccess.com/two-way-radios-2-0-landscape-changing/
So for BCA user's it's business as usual. For everyone else....well....
27,405
Dude... just skimming through that, made my head hurt :face-icon-small-con
YA, I hear ya.
I am a licensed "Extra" class HAM operator. So all this means more to me than most sledders.
The bottom line is BE CAREFUL if your running an illegal radio and/or using it without a license.
The Feds can extract some serious money from your pocket.
27,405
BCA DID IT RIGHT.
Their Radios are 100% CERTIFIED and LEGAL.
They are a NONE ISSUE as far as this new rule goes!
BeartoothBaron
1,245
1,323
Roberts, MT
BCA DID IT RIGHT.
I'd bet that companies like BCA, Cobra, Midland are largely the ones pushing these kind of changes. After all, why buy something so limited when for almost the same money you can buy something with ten times the capabilities? Either way, the thinking behind these rules is draconian, nanny-state meddling. Sure, you'll never break the law if your radio is incapable of it, but in an emergency, I'd rather be able to get help and live than die FCC-compliant. For those intent on mis-use, banning sales and import isn't going to stop anything. For the rest of us who have an interest in multi-band radios, we're generally smart and honest enough to find out what bands we can use and make sure we're compliant. I'm tired of a government that is constantly telling us we can't have this or that because we might mis-use it. I'm fully aware of what happens if the radio spectrum isn't policed – they should throw the book at people who deliberately break the rules – but I'm tired of needing a license every time I turn around, and the implicit assumption that I'm either too incompetent or too lawless to act responsibly on my own. What I do is my own business, but for anyone who has half a mind to buy one of these radios, I'd suggest buying three while you still can.
Timbre
2,504
Southwestern Idaho
^^ That is true, and is the answer to one of the questions in the HAM radio licensing test :)
But . . . if you are using a radio that is NOT capable of transmitting with adequate power or on the right frequency to access a repeater, (like BCA and others) that radio is almost useless in the event of a backcountry emergency. As for me, i would rather have the radio that i can at least program to operate on some HAM channels, or SAR, and/or access repeaters. . . then hope to never have to use it for that purpose.
BeartoothBaron
1,245
1,323
Roberts, MT
That's my point exactly, Timbre! Christopher is right that if you've got a UV-5R or whatnot, in an emergency you can use whatever frequency or power setting you see fit, but the new regulations seem directed largely at pushing those radios out of the market. By FCC compliant, I meant the radio itself – unlike the gray market radios, no commercial radio can blast out 8W over FRS/GMRS, MURS, SAR, or HAM frequencies because the FCC would never certify them. So, once again, the government "solution" to potential misuse is to make the capability illegal – it's like trying to prevent illegal off-roading by banning the sale of 4x4s.
TecCrash
67
20
8
57
Middleton, ID
I have to believe that with the US Market being what it is, Baofeng and others will just make the radios compliant. The primary thing that makes them suspect to import restrictions is that they CAN communicate out of band, at too high of tx power rating and have removable antennae. I have several of them, the lure to use them out of band isn't for licensed hams, but for people that aren't licensed but want to use them on FRS/GMRS/MURS withut being stuck down at 1/2 or 1 Watt and want to be in the 5-8 Watt range. I bought my first UV-5R to build an APRS rig for sledding so that my wife could find me if I didn't show up at home, but then I realized I need to be licensed. Test was easy, didn't have to do Morse this time around :)
I truly believe that this is just a case of LAZINESS!
Lazy from the Manufacturers that don't want to lock the frequencies down to only tx in the assigned band plan by country.
Lazy from consumers that want the longer transmission range but aren't willing to spend the 5 hours or so of study time to pass a test. ( think Avy Training )
Stepping off my soap box.....
TecCrash
73's
KJ7FEO
TecCrash
67
20
8
57
Middleton, ID
But on the other hand I have a Corvette that does go way faster than the speed limit ( read Band Plan ) .... Just saying, it's about personal responsibility.
TecCrash
kcZ
19
9
3
Does the BaoFeng UV-5R have a selectable power setting? Can I operate on the lower power setting and not worry about Roscoe waiting for me at my truck? It would be nice to be able to operate at the higher setting in case of an emergency. I'm looking at getting our group a bunch of these radios just to make group events easier and in case someone gets stuck without the others knowing.
Pickin’ Boogers
384
319
You can operate at the lower setting, but in theory it might still be too powerful to be legal. That's if the advertised power is actual, which is unlikely. Responsible use probably won't get unwanted attention, but still wouldn't be "legal" even for reasons unrelated to power.
Continuing the Corvette analogy: You can drive it the speed limit, and maybe nobody will notice you've also got non-DOT tires and a modified exhaust system.
